| Ansbacher |
May 6 2020, 12:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Are the following two steering racks interchangeable -
914.347.014.00 914.347.014.01 I have a nicely rebuilt .00 rack (see pics) that I would like to install in my '74 2.0L. Research says the .00 is a rack from 70-72. Can I use it in my '74? Thanks. Ansbacher ![]() |
| mepstein |
May 6 2020, 12:35 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,774 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I'm under the impression that all 914 racks and even many 911 racks interchange.
| Ansbacher |
May 6 2020, 12:47 PM
Thanks Mepstein, I suspected that was the case.
Ansbacher |
| JFJ914 |
May 6 2020, 01:04 PM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States
The racks are interchangeable, IIRC the 2 mounting bolts are not. One rack uses short bolts, the other longer.
| Ansbacher |
May 6 2020, 01:24 PM
| roblav1 |
May 6 2020, 02:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
65 to 68 911 racks are also interchangable. They have a quicker ratio.
| bdstone914 |
May 6 2020, 03:04 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,322 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Ansbacher
' date='May 6 2020, 11:18 AM' post='2812279'] Are the following two steering racks interchangeable - 914.347.014.00 914.347.014.01 I have a nicely rebuilt .00 rack (see pics) that I would like to install in my '74 2.0L. Research says the .00 is a rack from 70-72. Can I use it in my '74? Thanks. Ansbacher ![]() [/quote] All 914 and 911 racks are interchangeable but there are differences. Look the the height of the bosses for the mounting holes. There are two heights. Kind of built in bump steer. |
| Mikey914 |
May 6 2020, 08:30 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
As a re builder of these racks I can attest that all are interchangeable except the early 912 ones.
In fact we get 914 racks sent in that are 911 racks all the time. The big problem is that there are 6 major variations and even more internal differences in bearings retainers, and drag pucks as well as the outer guide bushings that there are 3 major variations. The castings are machined to each of these. This is one of the reasons we can't just sell a kit to rebuild. |
| PlaysWithCars |
May 7 2020, 09:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 542 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest
Interested to learn more about the racks with faster ratios. Worth swapping for a dedicated autocross car? How different is the ratio?
| bdstone914 |
May 7 2020, 10:03 PM
@Ansbacher
' date='May 6 2020, 12:24 PM' post='2812292'] [quote name='JFJ914' post='2812289' date='May 6 2020, 03:04 PM'] The racks are interchangeable, IIRC the 2 mounting bolts are not. One rack uses short bolts, the other longer. [/quote] The inevitable fly in the ointment. Damn! Anyone know the bolt specs for a 914.347.014.00 rack? Ansbacher [/quote] It is a 10mm bolt . Measure the depth of the hole or do a test fit with the bolt to be sure it do, not sure if the grade 8.8 or 10.9. The lenght is about 25mm. The bolt takes a split loch washer and account for the rack thickness of about 5mm. You want maximum thread engagement. |
| roblav1 |
May 8 2020, 09:59 AM
65 to 68 ratio: 1:16.5 with 2.8 turns stop to stop
69 to 73 911: 1:17.78 with 3.1 turns stop to stop |
Lo-Fi Version | Time is now: 17th June 2026 - 01:33 PM |
