1974 2.0 Hesitation at 3100RPM (Solved) |
Nojoah |
May 7 2020, 12:32 PM
Member Group: Members Posts: 119 Joined: 6-May 20 From: Ontario Member No.: 24,234 Region Association: Canada |
Hello again, I just posted yesterday with some questions about installing an ignitor II Electronic ignition. Well today I went to change out the points and apparently the previous owner had installed an ignitor I already. I replaced this anyway and the car still has the same issue so I'm assuming it has nothing to do with the ignition. The car runs perfectly, idles great when warm, and revs with no hesitation while in neutral. While driving though, it accelerates great up until about 3100 RPM when the car seems to hesitate and refuses to rev past when the throttle is pushed. A slight bucking can be felt if you pay attention but VERY slight. If you back it off and apply extremely gentle and steady pressure the car does seem to rev past this point slowly though... Any ideas? Has anyone had a similar problem with their car? Timing is set perfectly at 27 BTDC at 3500 RPM.
Note - Car still had original FI, with original distributor (Apart from electronic ignition) |
ctc911ctc |
May 8 2020, 06:55 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Hi,
The trigger points should be checked, there are many threads within 914world that address all of their nuances. Do your search outside with google, the internal search is.......wanting....... However, trigger points are related to the position of the throttle (pedal) not the RPMs. A very common cruise RPM is on or around 3000-3200. Many people have cured the dreaded Bosche Djet bucking problem with a little turn of the MPS. Many people rally against this. 1. Check the TPS 2. Vacuum - if you have not checked all of the hoses and the Plenum, take off the throttle body, plenum, and headers. Replace ALL gaskets and also pressure check the plenum. mine was very porous. 3. If your MPS has the epoxy missing(check threads here in 914world) quarter-turn counterclockwise (clockwise?) at a time. For a real trip, take a look at this........ https://oldtimer.tips/en/d-jetronic/56-connector#vw4 |
Nojoah |
May 8 2020, 08:26 AM
Hi, The trigger points should be checked, there are many threads within 914world that address all of their nuances. Do your search outside with google, the internal search is.......wanting....... However, trigger points are related to the position of the throttle (pedal) not the RPMs. A very common cruise RPM is on or around 3000-3200. Many people have cured the dreaded Bosche Djet bucking problem with a little turn of the MPS. Many people rally against this. 1. Check the TPS 2. Vacuum - if you have not checked all of the hoses and the Plenum, take off the throttle body, plenum, and headers. Replace ALL gaskets and also pressure check the plenum. mine was very porous. 3. If your MPS has the epoxy missing(check threads here in 914world) quarter-turn counterclockwise (clockwise?) at a time. For a real trip, take a look at this........ https://oldtimer.tips/en/d-jetronic/56-connector#vw4 Thanks a lot! I'll check the TPS today and let you gus know. Hoping it'll be a simple fix as I've got some other things to look at also. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:32 AM |
