> 1970 914/6, No Spark at Coil (Fixed- installed MSD 6A)
Joe C
post May 9 2020, 01:14 PM
Post #21
Recently replaced plugs, points, cap, rotor, wires, coil. Car was running great for about 150 miles then started to sputter like it was running out gas. Luckily made it to a gas station filled up and went on my way..... for about two miles and it just died!
This is a 1970 six with 45k miles. Its getting fuel, Points are good and correctly adjusted, CD box whistles when the key is on but there is no spark at the coil. Checked all the grounds and had my head in the engine compartment for hours looking for loose or broken wires.
Any ideas?????
And by the way, if you have classic car insurance make sure you opt in for the towing.
I didn't, $175.00 for the hook up and a 6 mile trip!!!
Joe C   1970 914/6   May 9 2020, 01:14 PM
Retroracer   Couple of suggestions: 1) check the polarity of t...   May 9 2020, 01:48 PM
Joe C   Thanks Tony, Already tried the old coil and no lu...   May 9 2020, 03:42 PM
johnlush   Joe, BTDT. In my case it was a bad ground to the ...   May 9 2020, 04:04 PM
porschetub   Tony and John are dead on with replies,the bosch 3...   May 9 2020, 06:04 PM
dakotaewing   Recently replaced plugs, points, cap, rotor, wire...   May 9 2020, 06:38 PM
IronHillRestorations   Make sure the CD box is plugged in good, and has a...   May 10 2020, 07:46 AM
Superhawk996   One thing I've learned is about half of igni...   May 10 2020, 08:30 AM
Superhawk996   One thing I've learned is about half of igni...   May 10 2020, 08:31 AM
Joe C   Make sure the CD box is plugged in good, and has ...   May 10 2020, 06:55 PM
porschetub   Make sure the CD box is plugged in good, and has ...   May 10 2020, 11:36 PM
IronHillRestorations   Make sure the CD box is plugged in good, and has...   May 11 2020, 05:33 AM
rgalla9146   ^ :agree: with Perry Check for gas fro...   May 10 2020, 08:32 AM
porschetub   ^ :agree: with Perry Check for gas fr...   May 10 2020, 09:17 PM
Joe C   ^ :agree: with Perry Check for gas f...   May 11 2020, 12:27 PM
rgalla9146   [quote name='porschetub' post='2813841' date='May...   May 11 2020, 03:25 PM
ClayPerrine   Actually it's far easier and certainly more ...   May 12 2020, 07:33 AM
IronHillRestorations   Check the distributor cap and make sure it's s...   May 11 2020, 05:35 AM
ClayPerrine   This may help you.. http://www.914world.com/bbs2/...   May 11 2020, 07:18 AM
johnhora   Also I've found the early CDI boxes don't ...   May 11 2020, 07:49 AM
ClayPerrine   Also I've found the early CDI boxes don't...   May 11 2020, 07:52 AM
johnlush   Yep! :agree:   May 11 2020, 04:08 PM
- Lo-Fi Version Time is now: 15th April 2026 - 06:52 PM
