| ctc911ctc |
May 15 2020, 10:57 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,370 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
All,
I installed HELLA 9004 100/80WTB bulbs into my new Hella Glass housings. Rebuilt the headlamp system to perfection starting with all assemblies, wiring, relays (high Amp relays as well for the headlights). My challenge is the 100/80 bulbs are not bright enough........ (IMG:style_emoticons/default/chair.gif) I have enough current available at the lamps to power near anything (12 gauge from the fuse panel with a 30amp fuse). What would you suggest as a next step? Thank you, CTC911CTC (IMG:style_emoticons/default/silver914.jpg) |
| 87m491 |
May 15 2020, 01:50 PM
Member ![]() ![]() Group: Members Posts: 331 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States
"E" codes? As I get older it is harder to get visible quality light out of incandescent bulbs, but with E codes on the 944 and 911 etc. I still find to be more than adequate even before bumping up to 80/100 bulbs. Also running fogs could give you nice short range fill.
All, I installed HELLA 9004 100/80WTB bulbs into my new Hella Glass housings. Rebuilt the headlamp system to perfection starting with all assemblies, wiring, relays (high Amp relays as well for the headlights). My challenge is the 100/80 bulbs are not bright enough........ (IMG:style_emoticons/default/chair.gif) I have enough current available at the lamps to power near anything (12 gauge from the fuse panel with a 30amp fuse). What would you suggest as a next step? Thank you, CTC911CTC (IMG:style_emoticons/default/silver914.jpg) |
ctc911ctc Driving into a Bright Future May 15 2020, 10:57 AM
ClayPerrine
All,
I installed HELLA 9004 100/80WTB bulbs into... May 15 2020, 12:09 PM
Cairo94507 LED headlights. https://www.amazon.com/Headlight-... May 15 2020, 03:36 PM
anderssj Proper aim for e-code headlights is absolutely cri... May 15 2020, 04:16 PM
Proper aim for e-code headlights is absolutely cr... May 15 2020, 04:54 PM
Chris914n6 I ran a new 8ga from the battery to a mini fuse bl... May 15 2020, 05:02 PM
914forme Cibie Z beams if you can find a set with H4s, or N... May 15 2020, 05:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th September 2026 - 07:14 PM |
