Harbor Freight jackstands recalled!, Could collapse under weight! |
oakdalecurtis |
May 19 2020, 03:20 PM
Oakdalecurtis Group: Members Posts: 1,322 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Here’s a link to the Harbor Freight jackstands that are being recalled. Apparently the catch pawl can slip and allow collapse of the stands under load.
https://www.roadandtrack.com/car-culture/bu...-of-collapsing/ |
76-914 |
May 21 2020, 09:20 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,485 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Click bait video. "ha ha it totally failed" -- After he hooked a pry bar under it and then exerted substantial force on the pry bar without measuring the force on the bar and calculating the total force exterted on the jack stand lever. Later in the video he goes on to show that it isn't easy to accidentally release. What also isn't considered is that a failure of 1 jackstand probably won't kill you. Could it? Yes, in just the right scenaro but the weight would not crush to the ground and the other 3 stands would still bear weight. Now if you're only using 1 jack stand and working directly below it, that is just asking for trouble. I almost always back up a single jackstand with another. News Flash: working the the garage around heavy objects and power tools can be dangerous. Even full on two post and 4 post hoists have been known to fail unexpectedly. Extremely rare but it has happened. Standing under a two ton object is inherently dangerous to a degree. If we don't take responsibility for our own safety and actions, expect a set of jackstands to soon cost $500 to cover corporate liability and the costs of frivilous lawsuits. This sort of "experiment" makes a well proven jack stand design appear to be critically flawed though intentional misuse. Sort of like when NBC news was caught using ignitors to ensure that a "test crash" caught on camera would result in a firery crash. https://www.latimes.com/archives/la-xpm-199...1335-story.html Just for clarity -- I'm not against pin type either! Well said. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 19th April 2024 - 06:18 PM |
