How often do you replace your clutch cable? |
RickS |
May 20 2020, 09:09 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
My throw is starting to feel notchy again, which means it’s time to replace yet again. In 15 years this will be #6. I know Mark was looking at offering a better one but never saw the upshot.
So how often do you replace yours? It would sure be nice if they were self adjusting like old shoe type brakes. |
brcacti |
May 21 2020, 08:19 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
So are we supposed to have lots of grease on the cable and wheel where it makes the turn? Does the thicker cable or the 6 really fit the 4?
StarBear |
May 22 2020, 12:05 PM
Senior Member Group: Members Posts: 1,829 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Superhawk996 |
May 22 2020, 02:31 PM
914 Guru Group: Members Posts: 5,670 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
So are we supposed to have lots of grease on the cable and wheel where it makes the turn? Does the thicker cable or the 6 really fit the 4? Ditto the question. Grease -- No. Especially not on the pulley or the exposed cable Grease attracts and holds dirt and debris. You want light oil inside the cable housing as previously outlined. Hitting the pulley pivot with a bit of silicone spray every now and then isn't a bad idea. You want the pully to rotate with the cable, not have the cable being pulled over the pulley and/or have grease with sand in it being ground between the pulley and the cable. |
Lo-Fi Version | Time is now: 28th March 2024 - 05:09 AM |
