Rear Brake bleeding question |
Frankvw |
May 21 2020, 10:09 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Hi all, I replaced the calipers and pads and flex hoses in the rear. (1973 1,7)
Old brake fluid from reservoir removed with siringe and filled with new fluid. I did set the clearance on the inner and outer on both sides. Then I did bleed the brakes and checked the clearance again (was still OK) Now the proportioning valve part....do I need someone to push the pedal to the floor, keep pedal at floor and then I bleed again while pedal is down? Or does it work another way ? Or is it not needed after what I already did ? Thanks for your reply ! |
twistedstang |
May 21 2020, 01:54 PM
Member Group: Members Posts: 220 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None |
Pressure bleed with a homemade setup or a Gunson eezibleed and never look back.
Lo-Fi Version | Time is now: 19th May 2024 - 07:18 AM |
