Can’t get into rear trunk |
rosenfe |
May 21 2020, 10:47 AM
Senior Member Group: Members Posts: 549 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
My 74. Rear trunk .When I insert let, lock turns but will not release trunk when pushed in. There is a hole drilled under lock with rubber plug.
aturboman |
May 21 2020, 11:05 AM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
You can just barely access the rear trunk hinge bolts from the engine compartment and remove or loosen all 4 in a worst case scenario and lift the trunk from the rear.
Then with a long hooked wire and flashlight you can reach the latch to release it. I did this once on a car I bought with missing keys and a locked rear trunk. Not easy or fun and took a while but nothing was damaged in the end except for a couple knuckles. |
Lo-Fi Version | Time is now: 13th May 2024 - 08:41 PM |
