> Another Fuel Pump Location Thread
bkrantz
post May 21 2020, 08:56 PM
Move the pump (1973 2.0) from the stock location to the front? If so, cut an access hole like later years?
Can somebody please send a photo of the frunk rear wall, taken straight on, so I can get some dimensions for the hole?
stevegm
post May 21 2020, 08:59 PM
I’m working on the same problem now too. I’m thinking about locating it under the gas tank. I think that is a common solution. I don’t want to cut the front bulkhead.
ndfrigi
post May 21 2020, 09:26 PM
several members have place it beside the steering column.
This is what I may be doing also.
yellowporky
post May 22 2020, 12:41 AM
I did a lot of searching for photos too and this is what I concluded to be as correct as possible
Hope this helps
Tbrown4x4
post May 22 2020, 03:08 AM
I put a CB pump up front under the tank, with the filter mounted by the steering rack. DD like this for 3 years without problems. I do want to add the plate and hole to avoid pulling the tank if the pump fails. (You never know.)
I handled my pump wiring with a module from Revolution Electronics.
https://www.revolutionelectronics.com/Produ.../Fuel_Pump.html
I found it easier to wire the pump from the fuse panel, and I like the 3 second prime and the safety shut off. (No ign signal, no pump.)
If the module fails, you short the purple wires together and drive home.
mlindner
post May 22 2020, 05:10 AM
Well, I moved my tank and pump, just FYI. MarkAttached Image Attached ImageAttached Image
roblav1
post May 22 2020, 11:44 AM
I ran stainless lines, appropriately bent, through the boxed support structure into the tank compartment. Still need to wire it. Pump was recommended by PMO.
porschetub
post May 22 2020, 03:27 PM
QUOTE(ndfrigi @ May 22 2020, 03:26 PM) *
(IMG:style_emoticons/default/agree.gif) best location,I'am not a fan of having a fuel pump inside the car but that's just me,the undertray panel keeps the pump out of the weather and offers protection from knocks.
bkrantz
post May 22 2020, 09:06 PM
Thanks, everyone.
- Lo-Fi Version Time is now: 12th July 2025 - 02:19 AM
