Primer recommendation?, Windshield frame, eng comp, frunk & trunk, etc... |
jcd914 |
May 22 2020, 11:08 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I hope everyone is staying safe and healthy!
I am trying to get some loose ends tied up and start driving my 914. I need a recommendation on primer to use for touch up where I have had to grind or drill or weld on my 914. These are all places that are not usually visible and I am not worried about their looks, I am after something to protect the bare metal. I only need small quantity and application with a brush would be easiest. When I bought this 914 it had been stripped and repainted but I have had to fix some things. Most of the holes for the windshield trim clips had been welded up. (I don't know why?) So I had to grind through newish paint to locate some of the holes and drill new holes as needed. I need to prime the bare metal before I install the windshield. I'm in CA and I have already attempted to get some pinch weld primer for butyl but it is no longer sold in CA. I have some touch up to do in the engine compartment where the trunk hinges were broken loose and required repair. Who would paint a 914 without fixing the torn trunk hinge mounts? I had to grind body filler out of passenger side of the front trunk seal channel around the head light bucket. They had so much filler the seal would not fit in the channel. Of course when I ground through the filler in the channel I found rust under it and had to clean that up. There ares some other small places that need primer as well but it is all small stuff. Thanks Jim |
914e |
May 22 2020, 02:07 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I don't know if this would work for what you are doing. I like the Eastwood Internal Frame Coating Aerosol Green for hidden areas and seams it wicks in seams which I hope will keep rust from forming there. It has internal frame spray nozzle. You can switch the can to a regular nozzle and some places I sprayed into a can and brushed it on.
IronHillRestorations |
May 22 2020, 06:06 PM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The Eastwood products are good. I'd also suggest Kirker epoxy primer. You can get it in quarts, and it's more expensive than rattle can, but not as expensive as PPG or DuPont epoxy primer.
Lo-Fi Version | Time is now: 25th April 2024 - 12:29 AM |
