Dual Weber 40’s, Fuel lines |
KevinW |
May 22 2020, 11:43 AM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I am looking for a drawing or detail Or picture how to route the fuel lines. I have searched the web but no luck. I have an idea about the supply line but not sure about the return line?
Thanks |
KevinW |
May 22 2020, 06:34 PM
I will be using a Facet fuel pump. When not using a return line do you cap the return at the fuel tank?
ChrisFoley |
May 23 2020, 09:58 AM
I am Tangerine Racing Group: Members Posts: 7,909 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I will be using a Facet fuel pump. When not using a return line do you cap the return at the fuel tank? The answer is yes. A short piece of fuel hose, a 5/16" long (2+ inches) bolt with all the threads cut off and two hose clamps is all you need. Facet interruptor pumps (the square ones) are generally reliable and have been used by 914 owners successfully many times in the past. Usually a pressure regulator is required since they put out 6-8 psi which is too much for the carburetor needle valves. OTOH, most of the available rotary pumps are internally regulated to 3 1/2 psi and no external regulator is required. |
Lo-Fi Version | Time is now: 25th April 2024 - 11:57 PM |
