> Dual Weber 40’s, Fuel lines
KevinW
post May 22 2020, 11:43 AM
I am looking for a drawing or detail Or picture how to route the fuel lines. I have searched the web but no luck. I have an idea about the supply line but not sure about the return line?
Thanks
IronHillRestorations
post May 23 2020, 12:13 PM
I. I. R. C.
I may have been talking through my hat. There used to be a few different vacuum compensated fuel pressure regulators, but I did a search and didn't come up with much, except some very high dollar race car parts.
Like many others have posted, get a good quality 3.5 psi rotary fuel pump and you'll be good to go. If you have to use a solid state ratta-ratta-ratta pump, you can minimize the noise with rubber mounts
KevinW   Dual Weber 40’s   May 22 2020, 11:43 AM
brant   this has been a controversial topic for ever... a ...   May 22 2020, 01:29 PM
bbrock   There is another reason to keep the return line. ...   May 22 2020, 01:48 PM
Superhawk996   There is another reason to keep the return line. ...   May 22 2020, 02:05 PM
bbrock   I'm wondering if those with the 1/8 tank scen...   May 22 2020, 03:27 PM
Superhawk996   I'm wondering if those with the 1/8 tank sce...   May 22 2020, 03:48 PM
bbrock   Now I'm super curious! The contraption ...   May 22 2020, 04:06 PM
SKL1   That makes sense but I've been running carbs o...   May 22 2020, 02:06 PM
ChrisFoley   I have never used a return line on a carbed car an...   May 22 2020, 05:20 PM
IronHillRestorations   I'm with Chris on this. I've never run a ...   May 22 2020, 06:14 PM
KevinW   I will be using a Facet fuel pump. When not using ...   May 22 2020, 06:34 PM
ChrisFoley   I will be using a Facet fuel pump. When not using...   May 23 2020, 09:58 AM
bbrock   You can also get a bypass regulator that can be c...   May 22 2020, 06:47 PM
SirAndy   Facet pumps will drive you batty with the noise. ...   May 22 2020, 08:09 PM
mtndawg   Facet pumps will drive you batty with the noise. ...   May 22 2020, 10:25 PM
ndfrigi   [quote name='bbrock' post='2818051' date='May 22...   May 23 2020, 01:23 AM
mtndawg   [quote name='mtndawg' post='2818099' date='May 22...   May 23 2020, 01:19 PM
ndfrigi   [quote name='mtndawg' post='2818099' date='May 2...   May 23 2020, 02:10 PM
Ansbacher   The inventor of the Facet type pump is now sitting...   May 23 2020, 11:24 AM
IronHillRestorations   I may have been talking through my hat. There use...   May 23 2020, 12:13 PM
KevinW   Thank you everyone for the advice   May 23 2020, 04:40 PM
- Lo-Fi Version Time is now: 16th April 2024 - 08:05 AM
