Carb manifold sealing, use phenolic spacer or not |
North Coast Jim |
May 22 2020, 04:12 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Engine is out and I'm doing some investigations. Bought a set of Redline 40 IDFs for the engine build. They've run OK but not great. Couldn't keep lean idle set properly. drivability an issue, pops and backfires at times. Jetting changes made no difference. Suspected gasket air leaks. Should have done the starting fluid check but didn't.
While the engine is out took the manifolds off from the heads. The gasket as supplied from Redline is a thick phenolic (?) spacer with paper adhered to both sides. Found a defect in each one at both ports. Near the top of each port the phenolic has a defect - a void. The paper on each side covers the defect but does not seal the intake. Found evidence of a leak path at this area Question - do I need the phenolic spacers ?? Can't find them on line as single replacement parts. Read of a need to keep the carbs from heat soaking but the manifolds are aluminum and are 5" tall. Don't see a need for them. Am I correct in this analysis ?? Was thinking of using .060" gaskets with Permatex red (min film deposit ) at this interface instead. What wisdom can you all impart. Thanks for any and all input |
MikeM |
May 23 2020, 11:08 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Here's my 2 cents...
I had a terrible problem with fuel percolating in the carbs. After shut down the heat from the engine would be soaked up by the intake manifolds and boil the gas in the carbs. I'd say you definately need the phenolic spacers. I also used a spacer between the carbs and intakes which helped alot, along with proper float adjustment. Good luck... Mike |
Lo-Fi Version | Time is now: 6th May 2024 - 06:13 PM |
