Valve Jam Nut not 13mm |
4x4loyr |
May 22 2020, 04:29 PM
Newbie Group: Members Posts: 28 Joined: 25-September 14 From: So Cal Member No.: 17,951 Region Association: Southern California |
I'm attempting my first valve adjustment on my '74 2.0 ... and after thinking I finally got an idea as what to do, I was going to loosen the jam nut to move the adjuster screw, and my 13mm wrench does not fit.
A 14mm will fit, but it has a little slack. I didn't want to go any further without a little input. The motor was rebuilt just before I purchased the car several years ago, but I have zero paperwork on the rebuild. Any ideas? Suggestions? Or, are these just worn/rounded 13mm nuts? Thanks |
porschetub |
May 22 2020, 11:53 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I'm attempting my first valve adjustment on my '74 2.0 ... and after thinking I finally got an idea as what to do, I was going to loosen the jam nut to move the adjuster screw, and my 13mm wrench does not fit. A 14mm will fit, but it has a little slack. I didn't want to go any further without a little input. The motor was rebuilt just before I purchased the car several years ago, but I have zero paperwork on the rebuild. Any ideas? Suggestions? Or, are these just worn/rounded 13mm nuts? Thanks Worn and rounded some people seem to overtighten them to crazy torque which isn't needed... |
Lo-Fi Version | Time is now: 25th April 2024 - 08:34 PM |
