Rear view mirror dismantling |
dt4 |
May 23 2020, 12:43 PM
Senior Member Group: Members Posts: 502 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
can the rear view mirror be taken apart to swap the glass and tilt mechanism?
I have 2 that arent great that could be used to make one good one thanks |
914Sixer |
May 23 2020, 03:23 PM
Mirror part is pressed to fit. Base and mounting pieces can be changed.
dt4 |
May 24 2020, 12:41 AM
rgalla9146 |
May 24 2020, 05:06 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
AFAIK if the orbital ball is loose or the day/night lever is broken the mirror is toast.
Do you have a remedy Mark ? |
914Sixer |
May 24 2020, 06:29 AM
No other fixes that I know of.
bdstone914 |
May 24 2020, 09:20 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@dt4
You can pop out he glass carefully to access the nut inside of the mirror housing. A glass shop can make a new mirror. they need some clearance aronud the mirror. I had one made and the glass broke before installed because the mirror fit was too tight. The mirror glass retainer or backing is usually shot causing the mirror to rattle. A gob of silicone rubber behind the mirror will secure it. |
dt4 |
May 24 2020, 12:19 PM
thanks chaps
Ill figure out what out do now i know what the options are |
Lo-Fi Version | Time is now: 14th May 2024 - 10:44 AM |
