Replaced Shifter Bushings, Now it pops out of 5th Gear |
gonzo54 |
May 24 2020, 04:30 PM
Orange Crush Group: Members Posts: 224 Joined: 10-May 19 From: Seal Beach, CA Member No.: 23,112 Region Association: Southern California |
I need some help from you guys. I just replaced the Ball Cup, Both Coupler Bushings, Firewall Bushing and Shift Rod Bushing at transaxle (AKA Crown Bushing). Went on a test drive and everything is feeling much tighter and smoother-got into 5th Gear and it popped out. Tried several times and it continues to pop out-I don't want to keep on trying it in 5th and cause a problem or chip an tooth since it is not going in all the way. I didn't have any problems with popping out of any gears prior to replacing the bushings.
I've search the forum and haven't been able to find how to adjust the linkage. Thanks-Rick |
second wind |
May 26 2020, 10:53 PM
Senior Member Group: Members Posts: 855 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Ok...I have been tackling this for years...getting the slop out of the shifting linkage....is there any way that someone can make the final bushing that has been made out of bronse just a teensy ineesty a bit smaller so the slop is eliminated? I know us guys would lube the hell out of it so it would never bind up but we need closer tolerances I believe. Just a itsy bit closer tolerance would really help....don't you think??
gg |
Lo-Fi Version | Time is now: 17th May 2024 - 01:27 AM |
