Replaced Shifter Bushings, Now it pops out of 5th Gear |
gonzo54 |
May 24 2020, 04:30 PM
Orange Crush Group: Members Posts: 224 Joined: 10-May 19 From: Seal Beach, CA Member No.: 23,112 Region Association: Southern California |
I need some help from you guys. I just replaced the Ball Cup, Both Coupler Bushings, Firewall Bushing and Shift Rod Bushing at transaxle (AKA Crown Bushing). Went on a test drive and everything is feeling much tighter and smoother-got into 5th Gear and it popped out. Tried several times and it continues to pop out-I don't want to keep on trying it in 5th and cause a problem or chip an tooth since it is not going in all the way. I didn't have any problems with popping out of any gears prior to replacing the bushings.
I've search the forum and haven't been able to find how to adjust the linkage. Thanks-Rick |
Frankvw |
May 27 2020, 12:38 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
gonzo54 : that was a good and bad moment at the same time when you discovered that I guess :-) Good to hear it it solved !
Lo-Fi Version | Time is now: 17th May 2024 - 01:36 AM |
