Type4 blower assmbly block off plates? |
SKL1 |
May 26 2020, 02:09 PM
Senior Member Group: Members Posts: 1,600 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I've got some of the block off plates for the sheet metal on the way from bdstone. Does anyone make a good solution for the openings on the front blower assembly if you're not using heat exchangers? Would replace the little flaps.
TIA |
bdstone914 |
May 26 2020, 08:25 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I've got some of the block off plates for the sheet metal on the way from bdstone. Does anyone make a good solution for the openings on the front blower assembly if you're not using heat exchangers? Would replace the little flaps. TIA Leave they open. Blocking them disrupts the air flow inside of the shroud. If you really want to block them you need to make plates to go onside the fan shroud leading to the ports to the S branches. Under operation with heat exchangers they have air flowing out except when the electric fan creates a higher pressure closing the flaps for more heat at low engine RPM's. |
Lo-Fi Version | Time is now: 14th May 2024 - 07:50 PM |
