Type4 blower assmbly block off plates? |
SKL1 |
May 26 2020, 02:09 PM
Senior Member Group: Members Posts: 1,600 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I've got some of the block off plates for the sheet metal on the way from bdstone. Does anyone make a good solution for the openings on the front blower assembly if you're not using heat exchangers? Would replace the little flaps.
TIA |
SKL1 |
May 26 2020, 08:29 PM
Figured if I blocked them off it would allow more cooling air to go to the oil cooler and cylinder fins instead of just out to the atmosphere under the car. I realize if you still have the heating system and it is off it eventually just vents outside anyway but figured anything could help an AC'ed car, especially in Arizona!!!
Lo-Fi Version | Time is now: 14th May 2024 - 09:01 PM |
