Type4 blower assmbly block off plates? |
SKL1 |
May 26 2020, 02:09 PM
Senior Member Group: Members Posts: 1,600 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I've got some of the block off plates for the sheet metal on the way from bdstone. Does anyone make a good solution for the openings on the front blower assembly if you're not using heat exchangers? Would replace the little flaps.
TIA |
SKL1 |
May 26 2020, 08:29 PM
Figured if I blocked them off it would allow more cooling air to go to the oil cooler and cylinder fins instead of just out to the atmosphere under the car. I realize if you still have the heating system and it is off it eventually just vents outside anyway but figured anything could help an AC'ed car, especially in Arizona!!!
bdstone914 |
May 27 2020, 06:20 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@SKL1
date='May 26 2020, 07:29 PM' post='2819384'] Figured if I blocked them off it would allow more cooling air to go to the oil cooler and cylinder fins instead of just out to the atmosphere under the car. I realize if you still have the heating system and it is off it eventually just vents outside anyway but figured anything could help an AC'ed car, especially in Arizona!!! [/quote] Just blocking them off will have a negative effect on cooling. Think about what happens when air is blown into a blind hole. Do you run an oil temp gauge? It you can hit over 250 under sustained griving you need more oil cooling. |
Lo-Fi Version | Time is now: 15th May 2024 - 10:32 AM |
