FS:914-6 Conversion Race Car |
TOxner |
May 26 2020, 07:41 PM
I'm new here ... Group: Members Posts: 0 Joined: 26-October 17 From: Conway, AR Member No.: 21,546 Region Association: None |
For Sale 914-6 Conversion Race Car
Vin # 4752901673 Ran in HSR and SVRA The car has fiberglass front fenders and rear quarters. The front and rear trunks are carbon fiber. The doors and engine lid are steel. The car weighs approximately 1900 lbs. The engine is a 2.4 liter built on a 5R case. It has enlarged ports, 911 2.2 S pistons, and GE-60 cams. Induction is via Weber 40s on PMO tall manifolds. Exhaust is via equal length headers with SuperTrapp mufflers. The engine has only a few break in hours on it. The distributor is from 123 Ignitions with an RS advance curve. Ignition is by a MSD 6AL box. The pedals are modified so they pivot from the top. There are twin braking master cylinders with an adjustable balance bar between them. The clutch is hydraulically operated. The oil tank is mounted in the front trunk and holds 10 quarts. Dual Mallory fuel pumps supply fuel. Suspension is by Koni adjustable shocks. The car has an adjustable front sway bar, but no rear bar. Engine cooling is via a large front mounted oil cooler with a thermostat. The roll cage is tied into the front and rear suspension pickup points. The transmission has fresh synchros as well as a 904 mainshaft with A, H, M, R, V gearing. In addition, the trans has a ZF clutch type limited slip differential. There is a cooler for the transmission. Front wheels are 3 piece 15X7. The rears are 16X9. The car is located in Conway, AR. Asking $18,500. Thanks, Tom Attached image(s) |
GregAmy |
May 27 2020, 06:50 AM
Advanced Member Group: Members Posts: 2,262 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
We need a "love" button on this forum. Swap you for a /4 historics racer... lol
TOxner |
Jun 13 2020, 08:21 AM
Price lowered to $16500. Thanks,
Tom |
TOxner |
Jul 13 2020, 08:43 PM
The 914 is sold. Thanks,
Tom |
Lo-Fi Version | Time is now: 29th March 2024 - 09:29 AM |
