1.8L starter problems, car won't start! |
aaronc70 |
May 27 2020, 10:31 AM
Newbie Group: Members Posts: 24 Joined: 4-September 13 From: Knoxville, TN Member No.: 16,348 Region Association: South East States |
I'm trying not to let my 1975 1.8L turn into a garage queen. A few weeks after taking the car in for some general service work (brakes, ignition, fuel delivery problems, etc). The car started and ran fine. Suddenly the car would not crank. I took the battery in to Autozone to be tested and it tested fine. Next I looked at the starter. After pulling it and taking it to my mechanic, it tested bad- it would spin but the solenoid would not push the gear out.
I ordered a starter off Amazon, consequently the starter drive gear did not look the same. My old one looked like this: https://www.autozone.com/batteries-starting...gen/beetle/2001 But the new one looked like this: https://www.amazon.com/gp/product/B007Y85Q7...=UTF8&psc=1 (or vice versa, I can't remember which. When I arc the contact points, the new starter spins and seems to spin and engage the flywheel fine. However the car still would not start using the key. I did some research and found this how-to on Pelican: https://www.pelicanparts.com/techarticles/9...tion_switch.htm I looked at the passenger seat belt switch and it seemed to be jumpered fine with good connection, so I assumed my starter switch at the key was bad. Despite my steering column not looking like the one in the tutorial, I was able to remove and swap it for a new one (Old was looked fine, was not cracked). The car still will not start with the key with a fully charged battery. Are there any switches that I am missing??? Any help is certainly appreciated! |
Coondog |
May 27 2020, 09:53 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Hope you get your 914 fixed. I am not a expert but maybe this list will help.
# Backdate Bumpers # Replace Riviera rims with Fuck rims # Delete you cell phone tower antenna # Dump 1.8 motor for a 3.2 Hope this helps, it sure made my 75 run better............ (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
aaronc70 |
May 28 2020, 11:08 AM
Hope you get your 914 fixed. I am not a expert but maybe this list will help. # Backdate Bumpers ehh, I'm OK with the bumpers, didn't realize they were not correct for the years. # Replace Riviera rims with Fuck rims I kinda like my rims, but I like the fuches too # Delete you cell phone tower antenna radio doesn't pick up crap without it, maybe if I update the radio I can return to a normal sized one. # Dump 1.8 motor for a 3.2 Definitely on the list, 6-cylinders seem to be pretty hard to find for less than $10K these days! Hope this helps, it sure made my 75 run better............ (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
Lo-Fi Version | Time is now: 30th April 2024 - 10:12 AM |
