1.8L starter problems, car won't start! |
aaronc70 |
May 27 2020, 10:31 AM
Newbie Group: Members Posts: 24 Joined: 4-September 13 From: Knoxville, TN Member No.: 16,348 Region Association: South East States |
I'm trying not to let my 1975 1.8L turn into a garage queen. A few weeks after taking the car in for some general service work (brakes, ignition, fuel delivery problems, etc). The car started and ran fine. Suddenly the car would not crank. I took the battery in to Autozone to be tested and it tested fine. Next I looked at the starter. After pulling it and taking it to my mechanic, it tested bad- it would spin but the solenoid would not push the gear out.
I ordered a starter off Amazon, consequently the starter drive gear did not look the same. My old one looked like this: https://www.autozone.com/batteries-starting...gen/beetle/2001 But the new one looked like this: https://www.amazon.com/gp/product/B007Y85Q7...=UTF8&psc=1 (or vice versa, I can't remember which. When I arc the contact points, the new starter spins and seems to spin and engage the flywheel fine. However the car still would not start using the key. I did some research and found this how-to on Pelican: https://www.pelicanparts.com/techarticles/9...tion_switch.htm I looked at the passenger seat belt switch and it seemed to be jumpered fine with good connection, so I assumed my starter switch at the key was bad. Despite my steering column not looking like the one in the tutorial, I was able to remove and swap it for a new one (Old was looked fine, was not cracked). The car still will not start with the key with a fully charged battery. Are there any switches that I am missing??? Any help is certainly appreciated! |
aaronc70 |
Jun 1 2020, 07:38 PM
OK, thanks a lot, I reconnected the tube into the right place (not the air flow meter as I originally guessed)
Well the new Bosch starter from AutoAtlanta came in today. I finally got it put in after dropping the nut about five times and it turns over, but it seems to turn over slower than the last correct starter that was in the car since I purchased it in 2013. The car would not light off and I've had no issues with that in the past. I even tried a little carb cleaner in the airfilter and it wouldn't hit a lick. I'm going to charge the battery overnight with hopes it spins faster. There was a this note in the new starter: Could this be my issue? Any other ideas? Bosch_starter_note_0001.pdf ( 173.97k ) Number of downloads: 92 |
Lo-Fi Version | Time is now: 30th April 2024 - 09:45 AM |
