front shift rod diameter |
AZBanks |
May 29 2020, 09:28 AM
Senior Member Group: Members Posts: 1,060 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Are the front shift rods the same diameter for side and tail shift transmissions?
My car is a '71 that was converted to a side shift transmission. I bought the Rix conversion shift bushing from 914 rubber but I can not get it to stay on place when I push the front shift rod through the firewall. It pushes the bushing out. The shift rod diameter where it passes through the firewall is .92 inches, 23.39 mm. What bushing do I need for that size front shift rod? |
AZBanks |
May 29 2020, 05:13 PM
@ Luke,
The PO changed everything for the side shifter except the shift rod in the tunnel. That is what threw me off. The original early shift rod is still in the tunnel but everything else has been swapped for the side shifter. I bought the tangerine bearing but when that didn't fit, I ordered the rix version and that doesn't work either, that's when I started measuring the rod diameter and found it is consitant with an early rod. @Mikey , I sent you a PM, thanks!! |
Lo-Fi Version | Time is now: 9th May 2024 - 02:59 AM |
