front shift rod diameter |
AZBanks |
May 29 2020, 09:28 AM
Senior Member Group: Members Posts: 1,061 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Are the front shift rods the same diameter for side and tail shift transmissions?
My car is a '71 that was converted to a side shift transmission. I bought the Rix conversion shift bushing from 914 rubber but I can not get it to stay on place when I push the front shift rod through the firewall. It pushes the bushing out. The shift rod diameter where it passes through the firewall is .92 inches, 23.39 mm. What bushing do I need for that size front shift rod? |
Luke M |
May 30 2020, 06:11 PM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Also check this seat belt bolt. It maybe too long and hitting the shift rod?
Attached image(s) |
AZBanks |
May 31 2020, 01:15 AM
bdstone914 |
May 31 2020, 08:21 AM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@AZBanks
' date='May 31 2020, 12:15 AM' post='2820643'] [quote name='Luke M' post='2820538' date='May 30 2020, 05:11 PM'] Also check this seat belt bolt. It maybe too long and hitting the shift rod? [/quote] Good catch. I'll take a look and see if they are making contact. [/quote] Remember that the rod moves up and down slightly when shifting gears. It is probably the wrong lenght bolt. They are special bolts with a 7/16 fine thread. I should have the correct bolt. Or grind down that bolt. Check the other reciever bolt to see it it is the correct lenght. The other side will not inferfere with the rod. |
Lo-Fi Version | Time is now: 9th May 2024 - 01:44 PM |
