single thrust cam bearing, what is this protrusion? |
malcolm2 |
May 30 2020, 12:57 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Assembling my engine. I noticed that the cam thrust bearing as a smaller tang. My case does not have the notch.
Since this is a smaller tang, designed a bit different. I am I supposed to tap it in place and let the action of bolting up the case crush it in place? I built a 1911 about 7 years ago, and I do not remember having issues like this. I am pretty sure I bought all my innards from Type4 store back then too. Clark Notice no notch in the saddle..... ? |
914Sixer |
May 30 2020, 01:07 PM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Look at your old bearing shells and see what you have. Thinking case should be notched.
malcolm2 |
May 30 2020, 01:14 PM
May 30 2020, 02:19 PM
Resident German Group: Admin Posts: 41,602 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I am I supposed to tap it in place and let the action of bolting up the case crush it in place? That sounds like a great start for a engine rebuild horror story ... (IMG:style_emoticons/default/icon8.gif) |
Jonathan Livesay |
May 30 2020, 02:30 PM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
I am I supposed to tap it in place and let the action of bolting up the case crush it in place? That sounds like a great start for a engine rebuild horror story ... (IMG:style_emoticons/default/icon8.gif) No crushing is probably a good general rule of thumb for any bearing, eh? (IMG:style_emoticons/default/dry.gif) |
dr914@autoatlanta.com |
May 30 2020, 02:32 PM
914 Guru Group: Members Posts: 7,810 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the cases have relieved places for the tabs
914sgofast2 |
May 30 2020, 07:11 PM
Senior Member Group: Members Posts: 613 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
That won’t crush; it will distort and pinch the bearing if you tighten it up in the case. Camshaft probably won’t turn easily, if at all.
porschetub |
May 30 2020, 07:19 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Tang is to prevent rotation of the bearing,there must be notch in the other case half otherwise that's the strangest case I have seen.
malcolm2 |
May 30 2020, 08:02 PM
the cases have relieved places for the tabs The picture shows that there is no notch in the case. The other picture shows the old bearing had no tang. Doc are you saying you have never seen a case without 6 notches for 6 tangs for the cam bearings? |
malcolm2 |
May 30 2020, 08:05 PM
I am I supposed to tap it in place and let the action of bolting up the case crush it in place? That sounds like a great start for a engine rebuild horror story ... (IMG:style_emoticons/default/icon8.gif) Just throwing out options. Don’t remember how the cam bearings in the last engine I built were set up. Anybody got pictures of a notch on the thrust saddle for the cam? |
malcolm2 |
May 30 2020, 08:15 PM
Tang is to prevent rotation of the bearing,there must be notch in the other case half otherwise that's the strangest case I have seen. Close but no cigar. Even if it did fit, the last bearing has a tang and the saddle has no notch. Fuzzy pic but i tried to install the thrust bearing in the right half and the tang and the notch don’t line up. |
malcolm2 |
May 30 2020, 08:23 PM
malcolm2 |
May 30 2020, 08:24 PM
Mark Henry |
May 31 2020, 06:57 AM
Grind or file the tang off, I do this every build. The cam bearing has a fair bit of crush plus the cam only spins half as fast as the crank, so it won't go anywhere. Just be careful, go slow, make sure to only remove the tang, but at the same time you have to remove the whole tang. Every build I do I use two thrust bearings, so yes I use two sets of cam bearings to get the 2nd thrust, but you can buy sets that are already dual thrust. This is the term "dual thrust bearings", it's not talking about the bearing function, it means there's a pair (2) of thrust bearings, which is of course a mod. Cam bearings are VW generic so the bean counters must of decided to only make one style of thrust bearing...with the tang. Interesting note the Porsche /6 intermediate shaft bearings are VW cam bearings, just the hole is in a different spot, but dimensional it's identical. |
malcolm2 |
May 31 2020, 08:35 AM
Thanks Mark. Filing was one thought. Glad you confirmed the best way to move on. BTW: type4store sells the double thrust set. +$20 vs the single set.
Thanks to all, Clark |
930cabman |
Dec 3 2021, 06:45 PM
Advanced Member Group: Members Posts: 2,998 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
A bit late to the party, I came upon this a few days ago. The tang for this thrush bearing is smaller than the rest of the cam bearings. My gut is telling me to cut a tiny notch in the case, Dremel.
And why the single thrust bearing?? Another victim of a bean counter? |
KSCarrera |
Dec 4 2021, 06:03 AM
Member Group: Members Posts: 306 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England |
And why the single thrust bearing?? Another victim of a bean counter? All VW Type 1 engines came from the factory with a single thrust bearing – the 'hot tip' when building a performance engine was to use two sets of cam bearings and steal the thrust bearing from the second set, filing off the tang so it would fit the case. Nowadays you can buy double-thrust bearing sets with a tang on just one half. |
Montreal914 |
Dec 4 2021, 11:33 AM
Senior Member Group: Members Posts: 1,541 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
QUOTE Nowadays you can buy double-thrust bearing sets with a tang on just one half. Is the type4 store the only source? |
Shivers |
Dec 4 2021, 12:21 PM
Senior Member Group: Members Posts: 2,327 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
zig-n-zag |
Dec 4 2021, 09:12 PM
Member Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
VW made these cam thrust bearings with a copper-impregnated bearing surface.
Part number 113-198-541. I have no idea if they are available now. |
Lo-Fi Version | Time is now: 19th April 2024 - 02:38 AM |
