single thrust cam bearing, what is this protrusion? |
malcolm2 |
May 30 2020, 12:57 PM
Assembling my engine. I noticed that the cam thrust bearing as a smaller tang. My case does not have the notch.
Since this is a smaller tang, designed a bit different. I am I supposed to tap it in place and let the action of bolting up the case crush it in place? I built a 1911 about 7 years ago, and I do not remember having issues like this. I am pretty sure I bought all my innards from Type4 store back then too. Clark Notice no notch in the saddle..... ? |
porschetub |
May 30 2020, 07:19 PM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Tang is to prevent rotation of the bearing,there must be notch in the other case half otherwise that's the strangest case I have seen.
malcolm2 |
May 30 2020, 08:15 PM
Tang is to prevent rotation of the bearing,there must be notch in the other case half otherwise that's the strangest case I have seen. Close but no cigar. Even if it did fit, the last bearing has a tang and the saddle has no notch. Fuzzy pic but i tried to install the thrust bearing in the right half and the tang and the notch don’t line up. |
Lo-Fi Version | Time is now: 16th May 2024 - 09:37 PM |
