Alternator light on? |
914Toy |
May 30 2020, 01:19 PM
Senior Member Group: Members Posts: 717 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
My alternator light comes on with ignition on, and stays on with engine running, and voltage stays at 12V regardless of rpm's. Was charging regularly at nearly 14V. The fan belt is in good order at spec tension. The alternator was reconditioned a couple of years ago and now has about 5,000 miles on it. The diode behind the gauge was also replaced, but I have had the gauge in and out a few times working on other issues - possibly damaging it(?)
Before removing the alternator for testing, could the diode behind the gauge be faulty preventing charging? If so, what is the spec of these diodes? Your suggestions will be welcome. |
Mikey914 |
May 30 2020, 03:51 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If you replaced your alternator light with a LED. The problem is the LED.
porschetub |
May 30 2020, 06:39 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
If you replaced your alternator light with a LED. The problem is the LED. With an LED lamp it won't work from the get go,only the stock lamp will work for excitation of the altenator. Bugger when you have a built in VR as changing them is a bit of a chore with the six, not so bad with a firewall opening. |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:32 PM |
