Alternator light on? |
914Toy |
May 30 2020, 01:19 PM
Senior Member Group: Members Posts: 717 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
My alternator light comes on with ignition on, and stays on with engine running, and voltage stays at 12V regardless of rpm's. Was charging regularly at nearly 14V. The fan belt is in good order at spec tension. The alternator was reconditioned a couple of years ago and now has about 5,000 miles on it. The diode behind the gauge was also replaced, but I have had the gauge in and out a few times working on other issues - possibly damaging it(?)
Before removing the alternator for testing, could the diode behind the gauge be faulty preventing charging? If so, what is the spec of these diodes? Your suggestions will be welcome. |
914Toy |
May 31 2020, 08:06 AM
What is the purpose of the diode attached to the alternator light terminal. The Haynes manual shows it connected in parallel with the blue alternator wire, connected to the brown with white stripe wires, but detail is difficult to be sure?
Lo-Fi Version | Time is now: 2nd May 2024 - 10:08 AM |
