torque wrenche for oil strainer, will this one work see pics |
brcacti |
May 31 2020, 06:28 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, in your opinions will this work for the oil strainer? Says 0 to 80 foot lbs see pics
ndfrigi |
May 31 2020, 06:39 PM
Advanced Member Group: Members Posts: 2,925 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
I think this kind is a lot better one.
michael7810 |
May 31 2020, 08:45 PM
Senior Member Group: Members Posts: 1,078 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
No. Oil strainer bolt torque is 9.4 Ft Lbs which is approx 113 in lbs and beyond the range of the wrench in the picture. You typically don't use the top or bottom 10% of the range so ideally you want one with a max value of at least 125 in lbs
ndfrigi |
May 31 2020, 09:52 PM
this one might do since it is for 5 to 19 ft lbs. except this is in nm (newton-meters)
https://tengtoolsusa.com/blogs/news/how-to-...ewton-meters-nm |
Lo-Fi Version | Time is now: 29th March 2024 - 07:59 AM |
