Fuel line replacement, fuel line replacement |
moe |
Jun 2 2020, 01:17 PM
Newbie Group: Members Posts: 39 Joined: 5-August 07 From: Stockton,ca Member No.: 7,977 |
I have a carb'd 74 2.0, is copper tubing an acceptable material to replace the fuel lines in the tunnel?
Coondog |
Jun 2 2020, 01:31 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
I have a carb'd 74 2.0, is copper tubing an acceptable material to replace the fuel lines in the tunnel? Lots of Rat Rods running Copper fuel lines for that old school look. 914 fuel lines are never seen. My Question is WHY ? Tangerine racing has pre-bent SS lines for a very reasonable price. Save your self the hassle buy SS lines. |
moe |
Jun 2 2020, 01:50 PM
I have a carb'd 74 2.0, is copper tubing an acceptable material to replace the fuel lines in the tunnel? Lots of Rat Rods running Copper fuel lines for that old school look. 914 fuel lines are never seen. My Question is WHY ? Tangerine racing has pre-bent SS lines for a very reasonable price. Save your self the hassle buy SS lines. The only reason why is my mechanic tells me he's replaced several over the years with copper. That is the only reason, i have not heard of anyone doing it with copper before. He is a 40 year Porsche mechanic and i trust his abilities. Thanks for the response |
twistedstang |
Jun 2 2020, 01:55 PM
Member Group: Members Posts: 220 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None |
I would be nervous about kinking soft copper while fishing it through the tunnel. Especially if it was just enough to starve you at high rpms.
Mark Henry |
Jun 2 2020, 02:34 PM
I wouldn't, the biggest fear I would have is if the copper line is just sitting in the tunnel, it's likely sitting in rust dust. Steel and copper doesn't get along together. If was totally suspended with copper or plastic covered hanger/clamps with proper grommets it might be OK... But why would you do that?
Original or SS lines is all I'd trust . SS kits often have a return line, but you only need one line for carb, so if you don't see one just ask for a single line. |
Rand |
Jun 2 2020, 03:12 PM
Copper is soft. Stainless is way stronger. Just use what is proven. Not like price is an issue. Especially when you can buy pre-bent lines in a kit ready to install from a known reputable vendor.
moe |
Jun 2 2020, 04:10 PM
Thank you all for the advice. I will go with the proven SS lines. Thanks Again!
porschetub |
Jun 2 2020, 04:21 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I used truck metal brake line for the front area,easy to bend with the correct tool which I had,strong and won't rust.
I wouldn't use copper in this situation. |
Big Len |
Jun 2 2020, 04:48 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
Has anyone replaced the original plastic fuel line with new original plastic fuel line?
bkrantz |
Jun 2 2020, 08:30 PM
914 Guru Group: Members Posts: 7,768 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
porschetub |
Jun 3 2020, 03:18 PM
Lo-Fi Version | Time is now: 21st May 2024 - 11:40 AM |
