Replacing Turn Signal Relay, What is correct positioning of wires on URO relay |
Maroon Loon |
Jun 2 2020, 04:16 PM
Newbie Group: Members Posts: 1 Joined: 18-February 17 From: Portland, Oregon Member No.: 20,847 Region Association: Pacific Northwest |
Hello,
I am looking to replace signal relay # 914.618.303.11. Is there a place to purchase another one? I came across a URO model with is listed as a replacement version, although the pins are located differently. What do you think is the correct positioning / location pins from the OEM part to the URO? See photos Many Thanks, |
Spoke |
Jun 2 2020, 06:14 PM
I believe the top relay pin layout is for the hi/lo beam selector relay. The lower relay pin layout is for the flasher relay. Universally available EP26 in many FLAPS is LED-compatible and pin compatible with the 914 OEM relay. A slight modification is needed for the K/C/C2 pin to drive the common connection of the tachometer turnsignal indicators. I resell modified EP26 flasher relays for the 914. |
second wind |
Jun 2 2020, 06:55 PM
Senior Member Group: Members Posts: 851 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
(IMG:style_emoticons/default/welcome.png) I believe the top relay pin layout is for the hi/lo beam selector relay. The lower relay pin layout is for the flasher relay. Universally available EP26 in many FLAPS is LED-compatible and pin compatible with the 914 OEM relay. A slight modification is needed for the K/C/C2 pin to drive the common connection of the tachometer turnsignal indicators. I resell modified EP26 flasher relays for the 914. Hello Spoke...so now I see that you do sell the modified turn signal relays for 914's....I must have missed it earlier. Could you please post the link for the purchase of such a relay? Thank you very much. gg |
Spoke |
Jun 2 2020, 07:06 PM
(IMG:style_emoticons/default/welcome.png) I believe the top relay pin layout is for the hi/lo beam selector relay. The lower relay pin layout is for the flasher relay. Universally available EP26 in many FLAPS is LED-compatible and pin compatible with the 914 OEM relay. A slight modification is needed for the K/C/C2 pin to drive the common connection of the tachometer turnsignal indicators. I resell modified EP26 flasher relays for the 914. Hello Spoke...so now I see that you do sell the modified turn signal relays for 914's....I must have missed it earlier. Could you please post the link for the purchase of such a relay? Thank you very much. gg EP26 For 911, 914 '70-'73 (Separate R and L Indicators) EP26 For 914 '74-'76 (Single L/R Indicator) |
Lo-Fi Version | Time is now: 1st May 2024 - 09:33 PM |
