Replacing Turn Signal Relay, What is correct positioning of wires on URO relay |
Maroon Loon |
Jun 2 2020, 04:16 PM
Newbie Group: Members Posts: 1 Joined: 18-February 17 From: Portland, Oregon Member No.: 20,847 Region Association: Pacific Northwest |
Hello,
I am looking to replace signal relay # 914.618.303.11. Is there a place to purchase another one? I came across a URO model with is listed as a replacement version, although the pins are located differently. What do you think is the correct positioning / location pins from the OEM part to the URO? See photos Many Thanks, |
Spoke |
Jun 2 2020, 06:14 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I believe the top relay pin layout is for the hi/lo beam selector relay. The lower relay pin layout is for the flasher relay. Universally available EP26 in many FLAPS is LED-compatible and pin compatible with the 914 OEM relay. A slight modification is needed for the K/C/C2 pin to drive the common connection of the tachometer turnsignal indicators. I resell modified EP26 flasher relays for the 914. |
Lo-Fi Version | Time is now: 16th May 2024 - 03:01 PM |
