Porsche OE 022-905-205-F for later 2.0L FI cars? |
Tdskip |
Jun 4 2020, 10:15 AM
worn |
Jun 4 2020, 10:32 AM
can't remember Group: Members Posts: 3,149 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Hi - I think I have this correct but not sure. Sorting through a jumble of parts and want to make sure I have the bits labeled correctly. Thanks! Try pbanders articles and posts about the FI. He has a table of parts, numbers and years. https://members.rennlist.com/pbanders/DJetParts.htm |
cary |
Jun 4 2020, 11:39 AM
What Worn said ................
Bleyseng |
Jun 4 2020, 01:13 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Its a 1.7L dizzy if that what you are asking. 022 numbers are 914 1.7 and 411/412 dizzys.
It will work fine as long as you rebuild it. |
bdstone914 |
Jun 4 2020, 07:01 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Tdskip
' date='Jun 4 2020, 09:15 AM' post='2821995'] Hi - I think I have this correct but not sure. Sorting through a jumble of parts and want to make sure I have the bits labeled correctly. Thanks! [/quote] Test the vacuun can. Most leak. If it does find a better distributor. They need to be disassembled and refreshed. The sliding plates get gummed up. |
porschetub |
Jun 5 2020, 12:59 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
[quote name='bdstone914' date='Jun 5 2020, 01:01 PM' post='2822094']
@Tdskip ' date='Jun 4 2020, 09:15 AM' post='2821995'] Hi - I think I have this correct but not sure. Sorting through a jumble of parts and want to make sure I have the bits labeled correctly. Thanks! [/quote] Test the vacuun can. Most leak. If it does find a better distributor. They need to be disassembled and refreshed. The sliding plates get gummed up. [/quote] (IMG:style_emoticons/default/agree.gif) never seen a "205 "with an advance plate not all stuck up,tear down is the only long term solution. |
Tdskip |
Jun 5 2020, 07:15 AM
Its a 1.7L dizzy if that what you are asking. 022 numbers are 914 1.7 and 411/412 dizzys. It will work fine as long as you rebuild it. Thanks - I was able to cross reference the "F" to a 1.7 car on the link provided as well. Appreciate the confirmation. I'll treat this one as a core (dirty as heck, needs a full rebuild). Have a good Friday gentlemen. |
Lo-Fi Version | Time is now: 28th April 2024 - 11:09 PM |
