Tis the Season for HOT START trouble, It CRANKS great - just will not fire |
ctc911ctc |
Jun 4 2020, 08:20 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
Lots of threads about FORD relays (really?, would not any starter relay work) but this trouble is different. In the manual, it says to hold the accelerator pedal to the floor when starting a DJet, so I tried this. I would like to FIX this so I can start when the car is hot like a normal car (yea, I know it is not a normal car), has anyone made a modification to the instrumentation to fix this issue? Perhaps CHT modification? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Jun 5 2020, 08:52 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Does it seem that it wants to catch if you release the key quickly (from the start to on position) when trying to start it? If so, your switch is broken. Also, check the voltage at your coil when cranking to see if you have 12v.
Lo-Fi Version | Time is now: 16th May 2024 - 04:36 PM |
