Get a Megasquirt, You will love it, They said |
RickS |
Jun 4 2020, 11:03 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Ok had a Megasquirt system installed on the 3.0. Much better throttle response and looks oh so sexy. Tuning was something else but it runs pretty well. Two issues:
1. After a cold start, the car is not drivable for at least two minutes, until it warms up. If you try to drive it cold it just stalls. Is this normal behavior? 2. The throttle is a tad touchy. Unless you slowly squeeze the throttle accelerating is like an on/off switch, with a millisecond of hesitation and then off we go. Is that normal or can that be tuned out? |
mb911 |
Jun 5 2020, 05:33 AM
914 Guru Group: Members Posts: 6,837 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Ok had a Megasquirt system installed on the 3.0. Much better throttle response and looks oh so sexy. Tuning was something else but it runs pretty well. Two issues: 1. After a cold start, the car is not drivable for at least two minutes, until it warms up. If you try to drive it cold it just stalls. Is this normal behavior? 2. The throttle is a tad touchy. Unless you slowly squeeze the throttle accelerating is like an on/off switch, with a millisecond of hesitation and then off we go. Is that normal or can that be tuned out? My old 3.0 with megasquirt ran well even cold.. Did you enrich the cold start cycle. |
Lo-Fi Version | Time is now: 9th May 2024 - 07:10 PM |
