Bolt, Where does it go? |
trojanhorsepower |
Jun 5 2020, 07:53 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So this bolt is the right thread and length for the shifter to coupling bolt. Is that what its for? Why the cut in the head?
Thanks Peter |
RoadGlue |
Jun 6 2020, 04:32 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Hey Peter,
I don't recall ever seeing a OEM slotted bolt anywhere on a 914. Could be something a previous owner fitted. |
76-914 |
Jun 6 2020, 04:35 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Throttle body clamp? (IMG:style_emoticons/default/confused24.gif)
URY914 |
Jun 6 2020, 04:43 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,389 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Hey Peter, I don't recall ever seeing a OEM slotted bolt anywhere on a 914. Could be something a previous owner fitted. I've parted out half a dozen 914 and I agree never seen one of those. (Someone will be along shortly to prove me wrong. (IMG:style_emoticons/default/sad.gif) ) |
TheCabinetmaker |
Jun 7 2020, 07:43 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I've seen that bolt, but not sure where.
Headlight adjuster bolt maybe? |
bdstone914 |
Jun 7 2020, 08:28 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have seen them. Maybe the air cleaner to throttle body boot clamp on a 2.0 or the clamp for the fan in the engine bay. |
bdstone914 |
Jun 7 2020, 08:30 AM
aharder |
Jun 7 2020, 01:52 PM
Advanced Member Group: Members Posts: 4,381 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
If I'm correct, the Tin screw mount in front of the alternator has a hex and slot. The one that screws to the fan shroud. not sure its that size .
trojanhorsepower |
Jun 7 2020, 07:06 PM
Thanks All,
Sounds like a hard no on the shifter. I'll hold onto it for later. Thanks again! |
rgalla9146 |
Jun 7 2020, 07:14 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Wrong size but same type used ( brass !) on 6 positive battery terminal.
can verify on another car soon. Attached thumbnail(s) |
bbrock |
Jun 7 2020, 09:55 PM
SirAndy |
Jun 7 2020, 10:54 PM
Resident German Group: Admin Posts: 41,618 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
rgalla9146 |
Jun 8 2020, 05:38 AM
Excellent ! |
rgalla9146 |
Jun 8 2020, 06:15 PM
This thread was started three days ago.
Today I noticed this cup that has been on my work bench for at least a month. Ain't that the way it goes ? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 5th May 2024 - 06:52 AM |
