Taking cover, front 911 suspension question |
ahycaramba |
Jun 5 2020, 08:47 PM
“I live my life a quarter mile at a time.” Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California |
Hello,
I installed a 84 911 front suspension with aluminum cross member. I want to cover up the crossmember. stock 914 cover plate will not work. Question for all you with 911 front suspension what are you using to cover up cross member? My guess is 911 plate but I thought I would ask before purchasing a 911 cover plate. Thanks in advance. Al |
bdstone914 |
Jun 5 2020, 08:54 PM
bdstone914 Group: Members Posts: 4,518 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hello, I installed a 84 911 front suspension with aluminum cross member. I want to cover up the crossmember. stock 914 cover plate will not work. Question for all you with 911 front suspension what are you using to cover up cross member? My guess is 911 plate but I thought I would ask before purchasing a 911 cover plate. Thanks in advance. Al You should be able to trim the 914 cover to fit. I think you just need to trim the side walls |
ahycaramba |
Jun 5 2020, 09:47 PM
Hello, I installed a 84 911 front suspension with aluminum cross member. I want to cover up the crossmember. stock 914 cover plate will not work. Question for all you with 911 front suspension what are you using to cover up cross member? My guess is 911 plate but I thought I would ask before purchasing a 911 cover plate. Thanks in advance. Al You should be able to trim the 914 cover to fit. I think you just need to trim the side walls Thanks Bruce. I'll try that. Lucky for me I didn't get rid of the original cover. |
Lo-Fi Version | Time is now: 12th May 2024 - 04:52 PM |
