Taking cover, front 911 suspension question |
ahycaramba |
Jun 5 2020, 08:47 PM
“I live my life a quarter mile at a time.” Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California |
Hello,
I installed a 84 911 front suspension with aluminum cross member. I want to cover up the crossmember. stock 914 cover plate will not work. Question for all you with 911 front suspension what are you using to cover up cross member? My guess is 911 plate but I thought I would ask before purchasing a 911 cover plate. Thanks in advance. Al |
914werke |
Jun 6 2020, 02:38 PM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I have the same. I cut the mounts from the steel cross member Drilled & welded them then bolted in place...fits & looks like factory.
porschetub |
Jun 6 2020, 04:43 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have the same. I cut the mounts from the steel cross member Drilled & welded them then bolted in place...fits & looks like factory. Hard to find mention of those brackets when doing this conversion,I knew they would be needed so I built a set from 6mm flatbar ,on the 911 the swaybar mounts do the job but from Porsche they are a mental price,besides I didn't know if the fitted. The ones I made were 14mm and 8mm holes @ each end. |
Lo-Fi Version | Time is now: 12th May 2024 - 10:53 PM |
