Anyone using the Patrick Motorsports 6 mount, Looking for a measurement |
Lg914 |
Jun 6 2020, 01:34 PM
Member Group: Members Posts: 53 Joined: 4-July 19 From: Lake Geneva Member No.: 23,275 Region Association: None |
If anyone is using the Patrick motorsports 6 tilting mount I need a bit of help. I need the measurement from the center pivot point to the bottom of the firewall.
Thanks for any and all help |
Larmo63 |
Jun 6 2020, 02:54 PM
It kind of just goes in one place.....? Doesn't Patrick have any install instructions, or it didn't come with any? I seem to recall mine did.
Attached thumbnail(s) |
sixnotfour |
Jun 6 2020, 03:19 PM
914 Wizard Group: Members Posts: 10,409 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
the measurement to the pivot wont help ,, they are 2 different manufactures... you need the measurement from floor pinch weld to the lower mount holes....se your other post for the number...
Lg914 |
Jun 6 2020, 03:24 PM
the measurement to the pivot wont help ,, they are 2 different manufactures... you need the measurement from floor pinch weld to the lower mount holes....se your other post for the number... Good to know. Now I am looking for the measurement from the lower mounting hole to the the pinch weld. |
Lg914 |
Jun 6 2020, 03:28 PM
It kind of just goes in one place.....? Doesn't Patrick have any install instructions, or it didn't come with any? I seem to recall mine did. Thanks for the help. I have a naroescape Mount which puts the motor lower than the Patrick mount. I am trying to figure out how much lower. So I can decide how to proceed. |
Jun 6 2020, 03:36 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It kind of just goes in one place.....? Doesn't Patrick have any install instructions, or it didn't come with any? I seem to recall mine did. Thanks for the help. I have a naroescape Mount which puts the motor lower than the Patrick mount. I am trying to figure out how much lower. So I can decide how to proceed. I like the Naro mount but it did give me some issues. I think it drops the engine too low and not only made the tin gap a bit but the engine sits lower and interfered with the shift rod. Ben had to rework his heat exchanger so I had clearance. |
sixnotfour |
Jun 6 2020, 03:40 PM
The real measuring point would be from the floor weld flange to the two bottom holes of the mount.. is 3 inches up from weld flange.
Larmo63 |
Jun 6 2020, 04:29 PM
My picture above is a 'before' dry mounted shot. Before we welded it, it got weld through primer, welded, and primed/painted.
Even though they are pricey, I like this mount. |
Jetsetsurfshop |
Jun 6 2020, 04:37 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
It kind of just goes in one place.....? Doesn't Patrick have any install instructions, or it didn't come with any? I seem to recall mine did. Thanks for the help. I have a naroescape Mount which puts the motor lower than the Patrick mount. I am trying to figure out how much lower. So I can decide how to proceed. I like the Naro mount but it did give me some issues. I think it drops the engine too low and not only made the tin gap a bit but the engine sits lower and interfered with the shift rod. Ben had to rework his heat exchanger so I had clearance. Any pictures of a Naroscape Mount in a car? Would like to see the mods to that were needed. Shift linkage and what ever else needs to be altered. I bought one off the classified's here. Hope it was a good idea. (IMG:style_emoticons/default/huh.gif) |
Jun 6 2020, 05:00 PM
It kind of just goes in one place.....? Doesn't Patrick have any install instructions, or it didn't come with any? I seem to recall mine did. Thanks for the help. I have a naroescape Mount which puts the motor lower than the Patrick mount. I am trying to figure out how much lower. So I can decide how to proceed. I like the Naro mount but it did give me some issues. I think it drops the engine too low and not only made the tin gap a bit but the engine sits lower and interfered with the shift rod. Ben had to rework his heat exchanger so I had clearance. Any pictures of a Naroscape Mount in a car? Would like to see the mods to that were needed. Shift linkage and what ever else needs to be altered. I bought one off the classified's here. Hope it was a good idea. (IMG:style_emoticons/default/huh.gif) Directions are to mount it at the bottom of the bulkhead. I would just raise it up 1” or better yet, dry fit it like Mark suggested. |
sixnotfour |
Jun 6 2020, 05:45 PM
Narrow needs provide info....... Lots more want stock than racing..... @naro914
Causing a lot of unnecessary tweeking, and problems Patrick's instructions are downloadable.. any fire wall deviation will change installed height... But Narows is designed lower.. |
sixnotfour |
Jun 6 2020, 06:37 PM
naro mount..low boy
sixnotfour |
Jun 6 2020, 06:39 PM
Patrick mount..install directions available to download PMS
Lo-Fi Version | Time is now: 23rd April 2024 - 05:03 AM |
