Differential Cover on Early Transmission, Anyone Have This Cover? |
914Sixer |
Jun 6 2020, 08:55 PM
Part number 901 301 311 2R. Number does not exist in current PET for 911/912/914 transmission side cover. All models show to use the 914 cover part number 914 301 311 01. Trying to solve a question. Seller says part is from a 69 912 902 trans case.
Cover has a clutch cable loop to hold up cable. Thinking someone might fab a bracket to hold clutch cable in close . Attached image(s) |
bdstone914 |
Jun 6 2020, 09:08 PM
@914sixer The number you posted is a casting number. It does look like an early 901 side cover. PET show it for 911/912 and 914. They probably kept the same part number and dropped the tab in later years. Looks like it would interfere with the clutch cable pulley bracket mounting on a 914. Attached thumbnail(s) |
jcd914 |
Jun 6 2020, 10:55 PM
Maybe a 71 or 72 911 trans with the pull clutch.
Jim |
sixnotfour |
Jun 6 2020, 11:45 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
70-71 rare ..not worn out..911S Registry.. what is the numbers on the the bottom side rib ??
rgalla9146 |
Jun 7 2020, 05:57 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
70-71 rare ..not worn out..911S Registry.. what is the numbers on the the bottom side rib ?? BINGO ! '70-'71 first version of the pull clutch. The trans is known by it's 911 prefix. Very unusual TOB too. When mounting the trans to the engine the TOB had to be rotated to attach it to the throwout arm. Stumps many a mechanic. Two year only clutch cable too. The loop on the side cover is a guide for the cable not a mount. |
Mark Henry |
Jun 7 2020, 06:17 AM
I had to cut that off when I was installing a 911 (901) trans into my bug. It interfered with the bug eng/trans frame horn.
My bug shifts as bad as a 914. (IMG:style_emoticons/default/biggrin.gif) |
Al Meredith |
Jun 7 2020, 03:26 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I have one of these covers if anyone needs or wants one let me know . AL
gms |
Jun 8 2020, 07:32 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
all my 1970 914/6s have this type of cover and I have found some 1970 914/4s with them.
914Sixer |
Jun 8 2020, 07:49 PM
Thank you Glenn. I knew I was not an old guy going South.
Krieger |
Jun 8 2020, 08:58 PM
Advanced Member Group: Members Posts: 4,712 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Lo-Fi Version | Time is now: 18th May 2024 - 10:41 AM |
