TPS variations - has anyone else noticed this ?, trouble shooting and comparing 2 with same part numbers but different stop tabs etc |
DRPHIL914 |
Jun 8 2020, 09:52 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i will post a picture here of 2 OE TPS with part number that cross references to the 75-76 2.0 D-jet cars.
i recently pulled mine due to it bucking badly @ 2800-3400 rpm on part load or mild acceleration. i also have one from Gatornapper to test for him and he is sorting out his D-jet parts and prepping to eventually going back from carbs to FI. What i found was that the stop peg is located on a different place. his essentially stops the tps from going all the way to the bottom at idle but not at the top on acceleration. mine on the right. stops the pivot of the shaft from going all the way on the top and keeps it from being able to go off track on max, his would not. they have the same part number. neither had been tampered with. also i bought mine as an NOS part 7-8 years ago and now may need to be replaced. his on the left has much more wear, actually live testing it causes same bucking but at a different lower rpm, due to wear pattern. any thoughts? i will be putting a new board on mine as soon as it arrives Right now i am running with it unplugged and no skip buck or hesitation now. i had been thinking it may have been an issue with my rebuilt MPS or developers valve set up or a wire shorting somewhere else, but it’s the TPS. Attached thumbnail(s) |
SirAndy |
Jun 8 2020, 10:22 AM
Resident German Group: Admin Posts: 41,640 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The part number printed on the boards is different. Yours seems to end with 006/008 (?) while the other one seems to end with 013
(IMG:style_emoticons/default/idea.gif) |
DRPHIL914 |
Jun 8 2020, 10:26 AM
The part number printed on the boards is different. Yours seems to end with 006/008 (?) while the other one seems to end with 013 (IMG:style_emoticons/default/idea.gif) back side the VW numbers both end in 111 but left one has an “A” thats the only difference. top number is hard to see but same on the back, but yes I see the board number appears to be different on the front. I don't see a dffference in the circuit though. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:48 AM |
