SpeedHut gauge panel, possible limited run - Any interest? |
tygaboy |
Jun 11 2020, 02:15 PM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
EDIT on 6/6/2021
I made 6 SpeedHut gauge panels today. See my post on page 4 of this thread for a "fresh off the plasma table" pic. If you're still interested, I should have these ready to go in a week or so. - these are .063 3003 aluminum - they will not be painted - they do not have the raised stamping for the dimmer - they are set up for a 4.5" center gauge, 4" outer gauges - 3 have holes for the dimmer, 3 don't $35 plus shipping from 94952. Yes, I'd said $20 earlier but that was a year ago and I was being too generous with my time and consumables. Just be thankful I'm not making them out of wood. (IMG:style_emoticons/default/laugh.gif) Let me know if you're interested. I'll probably make more once I get more material. Thanks again for your patience. Chris EDIT on 6/24/20: To the interested parties who've already contacted me or posted here to date: The plasma table is back in action so now I'm tuning the design. See my post from today (6/24) for the latest updates re: what's new and what I still have to do. _______________ As to price, it'll be the same thing I try and pull off whenever I do stuff for friends: Cost of materials and consumables and you buy me a coffee if we ever meet. I'm thinking $20 plus shipping. Thanks for your patience. Chris _____________ For those using or contemplating SpeedHut gauges, you'll find they are just a bit undersized compared to the stock gauges and require some sort of wrapping or spacer in order to fit well in the stock panel. I opted to give a go to working up a replacement panel and as I was making it, I thought, while I'm cutting one, I could cut a few more, if there was interest. This is V1 and it needs a couple minor tweaks, but you get the idea. Note that it has a 90 degree fold along the bottom edge that I'll stretch so the panel curves a bit, like the factory part. This one is .060 aluminum but I could do steel, too. Would anyone be interested in one? PM me, thanks, Chris Attached thumbnail(s) |
tygaboy |
Jun 24 2020, 05:41 PM
A bit of stretching to get things to sit nicely against the dash frame.
One item I still have to work up is a stamp/punch to set the recesses in the mounting holes so those stock tapered back screws sit nicely. Though I could opt to use a nicer looking fastener and change out the stock screw plates for something else... (IMG:style_emoticons/default/idea.gif) Attached thumbnail(s) |
76-914 |
Jun 25 2020, 11:53 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
A bit of stretching to get things to sit nicely against the dash frame. One item I still have to work up is a stamp/punch to set the recesses in the mounting holes so those stock tapered back screws sit nicely. Though I could opt to use a nicer looking fastener and change out the stock screw plates for something else... (IMG:style_emoticons/default/idea.gif) https://www.aircraftspruce.com/search/searc...e%20dies%203/16 |
tygaboy |
Jun 25 2020, 12:19 PM
A bit of stretching to get things to sit nicely against the dash frame. One item I still have to work up is a stamp/punch to set the recesses in the mounting holes so those stock tapered back screws sit nicely. Though I could opt to use a nicer looking fastener and change out the stock screw plates for something else... (IMG:style_emoticons/default/idea.gif) https://www.aircraftspruce.com/search/searc...e%20dies%203/16 @76-914 OK, that's what I'm talking about! Thanks for the lead! |
Lo-Fi Version | Time is now: 18th May 2024 - 12:39 AM |
