Overfilled the transmission |
AZBanks |
Jun 15 2020, 01:25 PM
Senior Member Group: Members Posts: 1,057 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
I installed a replacement transmission in the 71.
I may have overfilled the trans. Would the excess trans oil leak out the axle and front seals or does the presence of leaks mean I need to replace the seals?? |
GregAmy |
Jun 15 2020, 03:16 PM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I suppose it's possible that, with only "a few drops", it could just be splash overflow from the vent at the top.
Don't waste the oil you put in, try the easy stuff first. Simply let the car sit on the ground level, put a drain pan under the transaxle, and remove the fill (top) plug. Let it drain until it stops pouring out (it's not an exact science, just needs to be around the bottom level of the hole) and reinstall the plug. Then drive it. |
Tdskip |
Jun 15 2020, 04:29 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I suppose it's possible that, with only "a few drops", it could just be splash overflow from the vent at the top. Don't waste the oil you put in, try the easy stuff first. Simply let the car sit on the ground level, put a drain pan under the transaxle, and remove the fill (top) plug. Let it drain until it stops pouring out (it's not an exact science, just needs to be around the bottom level of the hole) and reinstall the plug. Then drive it. As Greg and others mentioned this is the way to do it. Don't sweat it on it being exactly the perfect amount of oil in there, once it stops draining out on a level surface you are good. Let us know how you get on. |
Lo-Fi Version | Time is now: 28th April 2024 - 06:47 AM |
