Overfilled the transmission |
AZBanks |
Jun 15 2020, 01:25 PM
Senior Member Group: Members Posts: 1,057 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
I installed a replacement transmission in the 71.
I may have overfilled the trans. Would the excess trans oil leak out the axle and front seals or does the presence of leaks mean I need to replace the seals?? |
PlaysWithCars |
Jun 15 2020, 10:46 PM
Senior Member Group: Members Posts: 523 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Also make sure the top vent is clear....it could be blocked,not likely but worth checking. (IMG:style_emoticons/default/agree.gif) Easy and free check. Is it leaking just sitting there or after driving? The vent only becomes a factor when driving and build temperature in the box. Unfortunately, a slight overfill like you described shouldn't result in a leak. Suspect you have old seals that needs some love. |
Lo-Fi Version | Time is now: 27th April 2024 - 03:42 PM |
