Targa Top to Window Top Seal, is this correct? |
MLinde |
Jun 16 2020, 09:08 AM
Newbie Group: Members Posts: 11 Joined: 31-March 20 From: Boyertown, PA Member No.: 24,084 Region Association: MidAtlantic Region |
Can anyone comment on the fit/gap shown here toward the front? The top seems to be very tight otherwise.
The other thing is that I'm not sure if I have the top to door window seal in correctly. I assume the side with the thin strip (rather than the flat side) is supposed to be facing out? However, the seal does not seat nicely when the door is closed... Suggestions? Thanks! Attached thumbnail(s) Attached image(s) |
Mikey914 |
Jun 16 2020, 10:20 AM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Here is a pic of the passenger side window (no main targa seal installed). The little "fin" goes on the outside to help keep water out.
MLinde |
Jun 16 2020, 11:24 AM
Thanks, I may need to adjust my window a bit, as it is now not seating correctly. Seems like it should be positioned just below that outer most lip.
Lo-Fi Version | Time is now: 17th May 2024 - 12:22 AM |
