GB for NON easy install Master cylinder, $69 each forgot to add free domestic shipping ($59 local pick up) |
Mikey914 |
Jun 27 2020, 11:05 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
PMs sent to all so far (IMG:style_emoticons/default/biggrin.gif)
BillJ |
Jul 4 2020, 10:47 AM
Senior Member Group: Members Posts: 1,091 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
mine just puked all over the floor. Should I get this one or the easy one?
Mikey914 |
Jul 4 2020, 11:27 AM
Really a matter of access. The job with these is getting the rubber stopper in to seat fully from underneath the car. Laying on your back, it can be a chore.
These are also on sale. |
BillJ |
Jul 4 2020, 11:29 AM
Have a pro two post lift so access isn't an issue. I need this sent stat to get it all done do I have to wait for the GB?
Highland |
Jul 4 2020, 02:06 PM
Senior Member Group: Members Posts: 511 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Does anyone ever just pull out the MC with the plastic lines, then reinstall with the plastic lined pre installed or is this impossible to do?
914Sixer |
Jul 4 2020, 02:22 PM
914 Guru Group: Members Posts: 8,867 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
What, you want to do it the easy way? Best to disconnect the rod from the pedal assembly before dropping the master cylinder down.
Montreal914 |
Jul 4 2020, 02:24 PM
Senior Member Group: Members Posts: 1,541 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
It would be nice to have some explanation as to the benefit of these parts and where is the improvement compared to the stock part.
I have read that installing the plastic lines in a new MC can be a pain, how does this part solves the problem? (IMG:style_emoticons/default/confused24.gif) How to use them, sequence of assembly, etc... Thank you for what is probably a good product (IMG:style_emoticons/default/beerchug.gif) |
Mikey914 |
Jul 5 2020, 07:10 PM
If you have ever tried to install the stock while on your back in a driveway. The "easy" version allows you to not have to try to pull the rubber stoppers in place while you have very little room to move around.
The Easy version has threaded nipples that allow for attachment mechanically without a lot of pressure required. |
Highland |
Jul 6 2020, 12:06 PM
@Mikey914 do you sell the pre-bent plastic tubes and short connecting tubes to the reservoir? Did not see it on your site.
Mikey914 |
Jul 7 2020, 12:33 AM
I do not have pre-bent lines but can provide the plastic lines required as well as the Hydraulic hose used to connect to reservoir.
I'll work at getting this listed up this week. -Mark |
Lo-Fi Version | Time is now: 23rd April 2024 - 08:08 AM |
