side shift linkage complete package, to convert your tail shifter into a side shifter |
brant |
Jun 24 2020, 09:41 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I have a complete set of shift linkage that is needed to convert to a side shifter.
you would still need: -new motor mounts (rubber) -a rear shift console plastic cover (914 rubber) -a forward shift plastic cover (914 rubber) -new shift linkage cone screws x2 (new) -a conversion firewall shift bushing, plus the 2 rear bushings (new) -replacement bushing for the fire wall connection knuckle (new) -the warm air guide for a side shift, if you want all stock tin in place (car will run without this piece) -a side shifter transmission, or change the tail cone and rods on your tail shift This sale includes: -both forward and rear shift linkages for a side shift -the actual shifter that is necessary for SS -the bushing in the bottom of the shifter, to mate to the shift rod (not in these pictures but included) -the motor bar that is for a SS -both motor mount brackets, required to use the SS motor bar -front and rear shift linkage attachment hardware to connect the bars at the shifter and shift console (front splined piece, and rear cup) -the aluminum flex knuckle for the fire wall connection I can also provide the SS tail cone and internal shift rods for converting your tail style transmission. I can provide these to the buyer for an additional $150 as part of the package The complete shift linkage is in good shape due to the motor bar, its a heavy package to ship I've been doing actual shipping cost, since rates vary depending on distance. so Shipping would be actual cost at UPS (I shipped a lighter tail shift package for 36, so this would be more, due to the length of the motor bar and weight) complete shift linkage conversion package: $400 + actual shipping SS transmission tail cone and 3 internal shift rods $150 optional to the buyer, not willing to split (will need to get pictures if buyer has interest) let me know your questions brant Attached thumbnail(s) |
rhodyguy |
Nov 30 2020, 06:33 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Nice. The white bushings look to be intact too. OEM plates are $80+. When you can find them. Clean assem. One less thing to worry about when converting or just replacing a worn linkage assem. And a bent engine support bar. The correct warm air guide is a bonus.
Lo-Fi Version | Time is now: 19th May 2024 - 08:51 AM |
