malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Help me out here. Working on the subject and can’t figure it out.
9590 cam. 0.426 lift on the card. Adjustable pushrod tool. I get to 0.426 lift. But the geometry between the swivel foot and the valve is wack. That is shortening the PR. Stretch out the PR and i get 0.430 lift and almost straight valve to adjuster. The foot is too tight to the 1.7 rocker boss. Bought some shims to lift the rocker stand and try that. Question is: why am I so far off the card lift? Does it matter? |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,454 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
Help me out here. Working on the subject and can’t figure it out. 9590 cam. 0.426 lift on the card. Adjustable pushrod tool. I get to 0.426 lift. But the geometry between the swivel foot and the valve is wack. That is shortening the PR. Stretch out the PR and i get 0.430 lift and almost straight valve to adjuster. The foot is too tight to the 1.7 rocker boss. Bought some shims to lift the rocker stand and try that. Question is: why am I so far off the card lift? Does it matter? Len Hoffman is the one to listen to....HAMInc.... shoot him a PM if he doesn't get here first |
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,742 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
When using the swivel foot on the 1.7 rocker arms you have to grind back the bottom of the rocker arm.
Some do it on a milling machine , but you can do it with a grinder. Just be sure to keep it level. . ![]() |
malcolm2 |
I do plan on removing material. Is it about 0.060” that needs to come off?
It just seems odd to have a published lift that can’t be used. |
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,262 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,294 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Don't worry about the lift vs the card.
Instead worry about getting the geometry correct. I take more than .060 off and the countersink must clear the foot in all directions. I don't use shims, at least not much shim. I cut the swivel foot down and recut the slot, as the screws can/could hit the valve cover. The cool trick for doing this is to put two 32T blades in your hacksaw, first cut the slot deeper, then grind off the excess thread. |
malcolm2 |
The counter sink is a nice touch. great picture. Tells the whole story. Not sure I can do that. Might have to take them somewhere.
I measured the boss (isn't that what the threaded part of the arm is called?). I got 0.492 on two, 0.502 on one and 0.496 on the last. I figured to take the 0.060 from the 0.492 and get 0.432. Then shoot for that on all 4. So at this point all my lift attempts with the adjustable push rod tool have yielded a lift with in +/- 5% of the card. So I should not worry about the final lift result? |
malcolm2 |
Mark Henry |
Don't worry about the lift vs the card. Instead worry about getting the geometry correct. I take more than .060 off and Cool. That is the direction I was heading. Don't really have much choice otherwise. Take the .060 off the smallest rocker then match the rest. After a generous countersink it won't look like much thread left, maybe less than a 1/4", but it's never been an issue. To get very little shim you only have the screw about 1-1/2 turns in, that's why you need a generous countersink and thus you have a lot of thread sticking out the top. If you need reassurance it's how Raby does them. The geometry... well I see some of the threads and giggle at all the complication (IMG:style_emoticons/default/biggrin.gif) At one half of measured lift the the adjuster screw should be in line with the valve stem. The rock (degrees) of the swivel foot from open to close should be equal. That's about all you need to know. Just an FYI If you have well machined heads, like Len's, then all the valve stems are equal, if you start into needing different lengths of PR there's something wrong with the head machining and/or case deck. |
malcolm2 |
Thanks for the input. Heads are camper specials.
malcolm2 |
I have removed about 0.060”. There is no way i am gonna be able to counter sink. I tried a shop today. He wanted nothing to do with it. He did try one, but just succeeded in heating up the rocker and was pissed that he may have ruined his tool. I have another to try tomorrow. But that guy succeeded in bending my 1.8 crank 7 years ago. Maybe one other shop to call in Nashville tomorrow.
So 8 rockers don’t weigh that much. Who has a shop i can send them too? Thanks. |
wndsrfr |
I have removed about 0.060”. There is no way i am gonna be able to counter sink. I tried a shop today. He wanted nothing to do with it. He did try one, but just succeeded in heating up the rocker and was pissed that he may have ruined his tool. I have another to try tomorrow. But that guy succeeded in bending my 1.8 crank 7 years ago. Maybe one other shop to call in Nashville tomorrow. So 8 rockers don’t weigh that much. Who has a shop i can send them too? Thanks. Send a PM to Len Hoffman HAMInc...... |
Highland |
Senior Member ![]() ![]() ![]() Group: Members Posts: 550 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California ![]() |
I used this guy and he seemed to do a good job.
https://www.thesamba.com/vw/classifieds/det....php?id=2130116 |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,954 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
I used this guy and he seemed to do a good job. https://www.thesamba.com/vw/classifieds/det....php?id=2130116 I used him as well. He's responsive and reliable. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,339 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
My 9550 Cam, .426 lift ended up at 436. Bonus!
nditiz1 |
I used this guy and he seemed to do a good job. https://www.thesamba.com/vw/classifieds/det....php?id=2130116 I used him as well. He's responsive and reliable. I also used him for my build. |
malcolm2 |
Len and i talked about other machine work. IIRC he does not do walk in stuff. Mostly his own head work. I was lucky on my 1911 build in 2012. HAM found a 2nd 1.8 head for me and rebuilt 2 for me. This time i went with new type 4 store camper specials. Built by HAM. I got better service working with LEN the 1st time vs TIV store.
As of right now I ended with IN 0.430 and EX 0.408 both yielded a good 1/2 lift angle. Just a smidge of swivel foot clearance with no counter sink. |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
With the 9590 you should dial in around a 27.1cm pushrod on the intake, to net .434” lift~
The exhaust side will usually never net more than .410” lift due to the rockers. Typically the pushrod on the exhaust side will run around 27.0Cm in length to net the most lift. These are examples, but usually pretty close. There’s 11 variables that play into this, the biggest being flycut depth and cylinder shim figures. I have taken up to .080” off of rockers, then lightened the 35 grams, with no issues. Those were for the 2563cc in my 356C, which has been together since 1999 and I haven’t broken a rocker yet.. |
Lo-Fi Version | Time is now: 11th July 2025 - 02:20 AM |
