Valve geometry hell |
malcolm2 |
Jun 25 2020, 09:19 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Help me out here. Working on the subject and can’t figure it out.
9590 cam. 0.426 lift on the card. Adjustable pushrod tool. I get to 0.426 lift. But the geometry between the swivel foot and the valve is wack. That is shortening the PR. Stretch out the PR and i get 0.430 lift and almost straight valve to adjuster. The foot is too tight to the 1.7 rocker boss. Bought some shims to lift the rocker stand and try that. Question is: why am I so far off the card lift? Does it matter? |
Mark Henry |
Jun 26 2020, 09:49 AM
Don't worry about the lift vs the card.
Instead worry about getting the geometry correct. I take more than .060 off and the countersink must clear the foot in all directions. I don't use shims, at least not much shim. I cut the swivel foot down and recut the slot, as the screws can/could hit the valve cover. The cool trick for doing this is to put two 32T blades in your hacksaw, first cut the slot deeper, then grind off the excess thread. |
Lo-Fi Version | Time is now: 25th April 2024 - 05:28 PM |
